February 1, 2024 at 12:13 am
Joshua Ottens
SubscriberHi, I was wondering if ansys can be used to determine the lumped model parameters of a transformer and also if it can be used to generate a frequency response analysis (FRA) plot from the transformer model?
If so does anyone knpw the maximum frequency that can be achieved for the FRA plot?Thanks!
February 6, 2024 at 1:28 pm
Ivonne Marti
Ansys EmployeeHi Joshua,
In Maxwell you can compute the lumped parameters (R,L,C) but you will need to run 2 different simulations, one to compute R and L using a magnetic solver and another one to compute C using an electric solver.
In Maxwell you can plot Inductance vs Freq, then please remember to specify a Freq Sweep in the Analysis/ Setup. There is not a maximum Freq value, but I would not recommend having several GHz.
Ivonne
February 21, 2024 at 10:03 pm
Joshua Ottens
SubscriberThanks for your reply Ivonne.
Do you know if the student version of ANSYS is capable of generating the frequency plot, or is a more advenced version required?
Thanks,
Josh
- The topic ‘Ansys for transformer FRA analysis?’ is closed to new replies.
3892
1414
1241
1118
1015
