Ansys Free Student Software
Ansys Fluent Working Very Slow.
    • Ahmed
      I recently downloaded Ansys Student 18.2 . I have been solving very basic fluid dynamics problems which may require 200 or 300 iterations at most to converge to the desired tolerance. However , my Ansys fluent software is working very slowly and is taking a lot of time to do the iterations. For instance to do 300 iterations it took close to one hour. My laptop has  Intel Core i5 -2430M with 8GB Ram. A friend of mine who has the same processor on his laptop did the same problem on Ansys.  He was able to do 300 iterations in 7.111s.
      I would also like to mention that once when I started my laptop and opened Ansys Fluent; it worked properly. It performed all the solutions in a matter of seconds. However this was a one time occurrence; when I restarted my laptop ; Ansys Fluent went back to performing slowly.
      I would be really grateful if someone could look into this matter.
      Thank you.
    • Raef.Kobeissi
      Hello 300 iteration within 7 seconds under the specs you mentioned sounds impossible to me even if the model was 2D. Could you please provide a description of the model you were running.
      I believe if the number of elelments is high in your model, an hour would make sense for 300 iterations on a PC similar to what you’ve described.
      Cheers
    • Ahmed
      Thanks for your response.
      I was running a simulation on a 2-D model with 4000 cells.I was simulating laminar flow in a channel. Since I just started using Ansys I mainly used default settings for all other other parameters except I just altered the inlet velocity magnitude. My tolerance specification was 10^-5 for velocity and momentum equations. My PC has Intel Core i5 -2430M with 8GB Ram and with in built graphic card ; Intel HD Graphics 3000.
      Let me know if you any need any further information. Thanks.
    • Ahmed
      Update:
      I restarted my Laptop and opened Ansys Fluent. it worked properly this time. I performed 1000 iterations in 27 seconds. Later, I restarted my laptop and opened Ansys Fluent again and it went back to performing slowly. However this time I copied the messages that appeared in the console tab in both slow and fast cases. All the messages were same except the following.
      Slow Case:
      Multicore SMT processors detected. Processor affinity set!
      Fast Case:
      DESKTOP-621A36I is already loaded (23.9042%). Process affinity not being set.
      I hope this helps you with your diagnosis.
      Thank you
  • The topic ‘Ansys Fluent Working Very Slow.’ is closed to new replies.
