ANSYS-FLUENT VOF on Moving MESH
    • zafrul
      Hi...I am trying to simulate the motion of a water(bottle) rocket caused by its thrust(ejecting water&air) using explicit 2 phase VOF ,Dynamic  Mesh and 6 DOF UDF.Without 6 DOF(static simulation), everything runs smoothly but when 6 DOF is checked,pressure inside bottle becomes very high and both bottle and water appears static and finally AMG solver diverges.When I use air only everything also runs smoothly as expected(bottle shoots up)..What could the problem be !!!..any help would be appreciated.
    • Raef.Kobeissi
      What are your boundary conditions? Can you send some picture for the way your problem is setup. It is difficult to judge without checking the setup.
      Regards
    • zafrul
      It seems that I couldn't attach files of TIFF format-it keeps displaying FILE EXTENSION NOT ALLOWED.Is there any way to get around this
    • zafrul
      Ok....Mr Kobeissi..I am attaching all the necessary filesinitial pressure
  • The topic ‘ANSYS-FLUENT VOF on Moving MESH’ is closed to new replies.
