August 20, 2024 at 10:47 am
Berker ÖZKARADUMAN
SubscriberI want to define a custom field function which includes dP/dx,dP/dy.I did the following 1.solve/set/expert n n yes no 2.İterate 1 iteration. Even though I have done previous 2 steps,I cannot see dP/dx contour in Fluent,it says that it is not defined in contours.How can I turn on pressure gradients.I want to define shock sensor which is dot_product(velocity vector, Pressure Gradient)/a*Magnitude(Pressure Gradient).I am using version 23.2 on linux.
August 20, 2024 at 11:06 am
Forum ModeratordP/dx is in the Derivatives section of contours, and should be available. Are you using the pressure or density based solver?Â
August 20, 2024 at 11:51 am
Berker ÖZKARADUMAN
SubscriberI am using pressure based coupled solver.
August 20, 2024 at 12:27 pm
Berker ÖZKARADUMAN
SubscriberI export case data file.I import having completed analysis.However, derivatives are not available for custom field functions.Moreover,IÂ cannot see dP/dx in y plane contour.
August 20, 2024 at 12:35 pm
August 20, 2024 at 1:25 pm
Berker ÖZKARADUMAN
Subscriber((dp-dx*Vx))
I could see these variables from my case data file.However, it gives unknown calculator button dp when I write following equation(you can see in the picture).
August 20, 2024 at 1:38 pm
Forum ModeratorWhat pictures? Please check as the Forum gremlins have been fairly hungry of late and keep eating things.Â
August 20, 2024 at 1:54 pm
Berker ÖZKARADUMAN
SubscriberDue to size issue I cannot upload pictures.But I am writing.
Error Object
((dp-dx)*Vx)
Error:Unknown calculator button dp.
August 20, 2024 at 2:18 pm
August 20, 2024 at 2:34 pm
