TAGGED: #fluent-#cfd-#ansys, case-file-read, export-file, write-file
February 23, 2024 at 2:14 pm
Vincent Paraboschi
SubscriberHello,
I have a problem with Ansys Fluent. Everytime I need to do something via the file explorer (read case, import mesh, write plots, ...) the file explorer is very slow and often freezes and crashes.I experience this problem on my workstation running on Windows 10. No problem while running on an HPC environment. Everyone in my company has the same problem on their workstation. I believe it may be linked to a third party of some kind that is installed in our Windows environment ?
Hope somebody can help me with that.
February 26, 2024 at 5:56 pm
MangeshANSYS
Ansys EmployeeHello,
Please check yiour home folders and also the default folder path that Fluent is set to run / open in
Are there any network drives or delays ?
February 27, 2024 at 3:33 pm
Vincent Paraboschi
SubscriberHello,
I checked that and everything runs locally.
March 12, 2024 at 3:26 pm
MangeshANSYS
Ansys EmployeeAre any of the folders below for your user profile set to a network location ?
%HOME%
%HOMEDRIVE%%USERPROFILE%
%TEMP%
The above variables can be copy pasted into address bar of windows explorer / file explorer to see where each one is pointed to
March 12, 2024 at 3:31 pm
Vincent Paraboschi
SubscriberHi,
No all the folders you sent are set in local on my computer. The problem is investigated at my company and apparently it is related to a third party called ZoneCentral. -
March 12, 2024 at 5:55 pm
MangeshANSYS
Ansys EmployeeThank you for the update. If the security software is temporarily disabled for a test, then does the delay go away and if it is enabled back then do you see the delay get introduced again ?
- The topic ‘Ansys Fluent UI File Explorer very slow / crashes’ is closed to new replies.
5934
1306
