August 7, 2018 at 2:25 am
Tom Doan
SubscriberHi everybody,
Could someone recommend me some book, pdf or video collections of the way how to use spectrum to processing noise or what other physical quality in ansys FLUENT tutorials?!
Thank you so much for advance.
August 7, 2018 at 5:36 am
DrAmine
Ansys EmployeeI recommend having a look into our Youtube Channel https://www.youtube.com/user/ANSYSHowToVideos as well as checking our standard tutorials in the help. For acoustic relevant topics I recommend attending a training.Â
August 7, 2018 at 7:41 am
Tom Doan
SubscriberThank you so much.Â
About acoustics i can do. but in here i want to to use spectrum to processing acoustic result.
Do you have any think do that.
Thank a lot .
August 7, 2018 at 8:24 am
DrAmine
Ansys EmployeeCan you elaborate a bit on you question? What are you willing to do? What are you requiring?Â
August 7, 2018 at 6:05 pm
Tom Doan
Subscribernow i can setup the model, plot some physical results. but now i want to plot spectrum of noise results.
I want to see what is the places, object or the physical quantity an effect on the noise?Â
August 7, 2018 at 7:00 pm
Konstantine Kourbatski
Ansys EmployeeHello,
Sec. 11.16.1.1.4. Fast Fourier Transform of CFD-post User Guide can be a good start point for you to familiarize yourself with the FFT signal post-processing. This post-processing can be done either is CFD-post or directly in Fluent. For more information, please refer to Fluent's User and Theory Guides for additional information. If you never did FFT and don't know much about spectral analysis of signals, then it would be a good idea to review some basics of its theory. There is a plenty of resources online on this topic which you can review.
August 8, 2018 at 2:08 pm
Tom Doan
do you have any video do about FFT ?
August 8, 2018 at 5:03 pm
Karthik Remella
AdministratorHello Tom,
You will be able to find a lot of videos covering the basics of FFT on Youtube. They hopefully will be able to bring you up to speed with FFT and help you move forward in your analysis.
Thank you.
Best Regards,
KarthikÂ
August 8, 2018 at 5:25 pm
Tom Doan
Subscriberthank you so much
August 15, 2018 at 7:48 am
Tom Doan
SubscriberHi everyoneÂ
Thank you so much for give me suggestion to do about ansys fluent.
now i still have problem with plot FFT in ansys fluent.
 My model setup is : cavitation + LES + AcousticsÂ
In my model i have setup get maximum Acoustics results of one point belong to time and i have input that data to FFT plot.
the results coming out just have frequency from 0 to 0.5 (Hz) like figure :
Do you know how to setup in ansys let FFT can get results with more frequency (10000 to 20000 HZ)
Thank you so much.
Best Regards,
Tom
- The topic ‘ANSYS FLUENT TUTORIALS’ is closed to new replies.
3597
1273
1107
1068
953
