Ansys Free Student Software
ANSYS Fluent Tutorial Guide 2021 R1
    • sulthan
      Hello, nI'm having difficulty with latest version of ansys fluent and I'm looking for ANSYS Fluent Tutorial Guide 2021 R1, from where can I download it?nGuides which are available online is for older versions.nThank Youn
    • Keyur Kanade
    • Gouthamvoodarla
      Hello sir,
      I am unable to access the 2021 R1 user documentation from the link provided above.
      Thank you.
      Have a look in Rules & Guidelines - there's a very useful thread in there.
    • pedramsamieyan
      Hi guys;
      I have a problem with accessing FLUENT user's guide contents. When I press it, I get the below message on the console of FLUENT:
      Error: CX_Send_Help_Command, could not get Help server port = 0.
      Is there any solution for this error? I appreciate that.
      Thank you.
      That's usually caused by the software not being able to access a browser and/or the internet. I assume you're online and the browser isn't blocked by the firewall?
    • Fatih KoçuÅŸağı
      if you reach it please share, I am researching this pdf todays.
      thank you
      If you click on Help in 2021R1 you should get to the correct version online. Otherwise, if you have access it's possible to download from the Customer Portal. Sharing the pdf is a really bad idea.
Viewing 7 reply threads
  • The topic ‘ANSYS Fluent Tutorial Guide 2021 R1’ is closed to new replies.
