June 9, 2020 at 2:31 pm
habo
SubscriberHallo.
I would like to write a ANSYS Fluent journal-file where I can extract the *.his summary from a DPM calculation and I only want to report one specific injection. This summary is called a Step-by-step summary.
So far I found:
;-- Report Particle
;-- Report to File
/display/set/particle-tracks/report-to File
/display/set/particle-tracks/report-type step
/display/set/particle-tracks/display no
;-- What to report
/display/set/particle-tracks/report-variables particle-mass
/display/set/particle-tracks/report-variables particle-x-position
/display/set/particle-tracks/report-variables particle-y-position
/display/set/particle-tracks/report-variables particle-z-position
/display/set/particle-tracks/report-variables particle-reynolds-number
/display/set/particle-tracks/report-variables particle-temperature
;-- Which injection
/report/particle-summary "inj01"
I am not sure about the last part '/report/particle-summary "inj01" ' and I have not found the command which actually writes the file.sum file!
When I record a journal file this is what I get:
(cx-gui-do cx-set-file-dialog-entries "Select File" '( "file.his") "Step By Step Particle Reports (*.his)")
Not exactly an TUI command and dependend on the commands before -- this looks like a GUI procedure.
Any help is appreciated.
Best Regards,
habo
June 9, 2020 at 2:54 pm
Forum ModeratorThe (cx-gui.... ) line is a GUI signal from a button click on a panel.Â
I'm not sure where the flag is without looking, check in /reportsÂ
June 10, 2020 at 2:57 am
habo
SubscriberI have found a solution. See https://www.cfd-online.com/Forums/fluent/75497-dpm-particle-tracking-tui-without-displaying.html
- The topic ‘ANSYS Fluent TUI: Writing an Step-by-Step Report via a journalfile’ is closed to new replies.
- affinity not set
4102
1487
1318
1156
