ANSYS FLUENT STUCK FOR HOURS IN CALCULATING THE SOLUTION
    • lancer
      I just followed a tutorial. But, when I used it, it got stuck in calculating the solution. Its 3D, Double Precession, Parallel with 2 Processor. I run in Parallel Setting in default and in msmpi MPI Type.
    • DrAmine
      Please leave all Interconnet and parallel option as defeault (Reset the launcher) and try again.
    • oelagab
      Hey i'm having the same problem. However, my model is a very simple 2 D geometry. I left the setting as it is parallel with one processor. Did you solve your problem ?
      • lancer
        I didn't solve it, I just change with latest version of ANSYS and its fix
  • The topic ‘ANSYS FLUENT STUCK FOR HOURS IN CALCULATING THE SOLUTION’ is closed to new replies.
