April 22, 2024 at 7:57 am
dbhands
SubscriberWhen viewing results of a simulation in Fluent and generating a simulation report from the Report Outline menu, an error message is displayed in the console when progress reads "Adding Data". The error is listed below:
Error: arg(2nd) out of range in substring
Error Object: 42
What can I do to troubleshoot this error? This feature has worked before on the same problem with the same setup, sucessfully generating a report. I have already tried resetting the solver and recreating all settings with no success.
Error occurs on both 2022r2 and 2024r1
April 22, 2024 at 10:14 am
Forum ModeratorCan you check all image and report definitions are valid and names are over four characters long.Â
- The topic ‘Ansys Fluent Simulation Report generation produces error message’ is closed to new replies.
