June 27, 2019 at 7:08 am
June 27, 2019 at 9:00 am
Forum ModeratorIt's a CAD issue and is typically triggered by two objects touching with zero overlap: which creates a surface with zero area or a volume that's zero thickness. Can you Unite the two curved bodies?
June 27, 2019 at 11:05 am
June 27, 2019 at 2:21 pm
Forum ModeratorIf they're surface bodies you may need to rethink how you build the model. What are you trying to do?
June 28, 2019 at 12:37 am
aorta3
Subscriberi must change it to 3D Solid Turbine ? -
June 28, 2019 at 9:47 am
Forum ModeratorNot necessarily, but you may need to split out a solid to avoid the problem. If you intend the blades to spin you'll also need a rotating fluid zone. Have a look in the tutorials for examples of those.
June 30, 2019 at 12:49 am
peteroznewman
SubscriberI found it difficult in ANSYS 19.0 to subtract a surface from a solid. Instead, I used the Thin operation to thicken the surface into a solid. I added a cylinder at the center and united that to the thickened blade. I created a large cylinder of air to enclose all the blades, then I sliced that into 120 degree slices. Finally, I was able to subtract the solid blade from the wedge of air.
Zoom into the hub at the center. Note that on the cut faces the hub can be seen on both sides, making for a clean mesh on each slice.
If these three slices are united back into a cylinder, that is the rotating mesh domain. An enclosure can be put outside this cylinder to represent the static domain for the air flowing toward this three blade turbine. ANSYS 19.0 archive attached.
November 23, 2023 at 4:10 pm
lidianne.pinto
SubscriberHello aorta3, Did you manage to solve the problem? I'm having a similar error -
November 29, 2023 at 2:43 pm
Dato
Subscriber@LidiannedePaula, i meet this problem too. do you solve it ?
- The topic ‘ANSYS FLUENT – result in non manifold bodies’ is closed to new replies.
5674
1890
1419
1304
---designmodeler.jpg?width=690&upscale=false)
