November 17, 2023 at 11:53 am
rxwm79
SubscriberHi,
I recently moved my temp folder from my C to D drive, as well as changing the temp file directory on Workbench. However, when I tried opening Fluent 2023 R2 from my Workbench, the app opens then closes itself immediately. I am not so sure how to solve this problem, or how it started in the first place.
November 20, 2023 at 2:37 pm
Rajeshwari Jadhav
Forum ModeratorHi Junya,
Can you verify if standalone fluent is working as expected?
November 20, 2023 at 4:30 pm
rxwm79
SubscriberI have tried running FLUENT by itself as an administrator, but it still experiences the same problem. I have also tried uninstalling and reinstalling ANSYS, but that does not work too.
To add on to this, I have also ran the following commands on Command Prompt, based on a similar post made on the forum:
set HOOPS_PICTURE=dx11
"D:\Program Files\ANSYS Inc\ANSYS Student\v232\fluent\ntbin\win64\fluent.exe" 3d -t2To which Fluent did open but with the following error message:
Auto-Transcript Start Time: Â 12:37:02, 20 Nov 2023 GMT Standard TimeÂ
Current Directory: "C:\WINDOWS\system32"Â Â Â Â Â Â Â Welcome to ANSYS Fluent 2023 R2
       Copyright 1987-2023 ANSYS, Inc. All Rights Reserved.
       Unauthorized use, distribution or duplication is prohibited.
       This product is subject to U.S. laws governing export and re-export.
       For full Legal Notice, see documentation.Build Time: May 29 2023 07:58:23 EDT  Build Id: 10212 Â
Connected License Server List: Â Â*********************************************
Info: Your license enables 4-way parallel execution.
For faster simulations, please start the application with the appropriate parallel options.
   This is a student version of ANSYS FLUENT. Usage of this product
   license is limited to the terms and conditions specified in your ANSYS
   license form, additional terms section.
Host spawning Node 0 on machine "DESKTOP-91FAOKK" (win64).
Unable to execute (null) D:\\Program Files\\ANSYS Inc\\ANSYS Student\\v232\\fluent\\fluent23.2.0\\multiport\\mpi\\win64\\intel2021\\bin\\mpiexec.exe  -n 2  -localroot -localonly -genv I_MPI_FABRICS shm -genv PYTHONHOME "D:\\Program Files\\ANSYS Inc\\ANSYS Student\\v232\\fluent\\fluent23.2.0\\..\\..\\commonfiles\\CPython\\3_10\\winx64\\Release\\python" -genv FLUENT_PROD_DIR "D:\\Program Files\\ANSYS Inc\\ANSYS Student\\v232\\fluent\\fluent23.2.0" -genv I_MPI_PIN disable  "D:\\Program Files\\ANSYS Inc\\ANSYS Student\\v232\\fluent\\fluent23.2.0\\win64\\3d_node\\fl_mpi2320.exe" -mport 127.0.0.1:127.0.0.1:52886:0 node -mpiw intel -pic default
(null)I have tried to set HOOPS_PICTURE to opengl2, msw/win and opengl but to no avail. I have also updated the graphics driver to the newest NVIDA Studio and Game Driver but am still unable to open Fluent properly.
November 20, 2023 at 4:40 pm
Rajeshwari Jadhav
- Clear the cache of the Fluent application by renaming the Ansys folder to Ansys.old (type in windows search bar %appdata% or C:\Users\username\AppData\Roaming\Ansys), rename .cfx and fluent.conf folder(C:/Users/username), relaunch the application to check if you can launch it successfully.
- Screenshot of the error if any?
- Is this issue occurring only for the CFD application, can you please check if you can successfully launch other Ansys applications too?
- When you launch fluent application (fluent utility) can you click on reset to default?
- Can you please check if any security software/ antivirus is blocking the Ansys CFD application?
- Can you please check if any av/security s/w is blocking it?
>> Launch the application then, Go to Start Menu à Event Viewer à Windows logs à Applications. Check for Error in it, send screenshot if possible.
November 20, 2023 at 4:55 pm
rxwm79
Subscriber1) I have renamed the folders and the same error occurs (i.e., the window opens then closes itself immediately). Using Command prompt, I get the following window on Fluent:
3) It would seem I am able to open other apps such as Discovery, Design Modeler or CFD Post, so it would seem that the problem is restricted to Fluent only.
4) When I open the window above I can click on tabs such as Physics, User Defined etc. but not File.Â
5) The app has been allowed through Windows firewall and other antiviruses.
November 20, 2023 at 5:15 pm
November 20, 2023 at 5:20 pm
rxwm79
SubscriberAs I mentioned, when I open Fluent directly the window opens then closes immediately and so I was not directed to the launcher. The screenshot in my reply was taken when I ran the following commands:
"D:\Program Files\ANSYS Inc\ANSYS Student\v232\fluent\ntbin\win64\fluent.exe" 3d -t2I was directed to the window where I took the screenshot earlier.
November 20, 2023 at 5:25 pm
Rajeshwari Jadhav
Forum ModeratorI see, can you check your event logs too?
November 20, 2023 at 5:27 pm
rxwm79
SubscriberHow do I access the event logs?
November 20, 2023 at 5:28 pm
Rajeshwari Jadhav
Forum ModeratorGo to Start Menu -->Event Viewer -->Windows logs -->Applications. Check for Error in it, send screenshot if possible.
November 20, 2023 at 5:31 pm
Rajeshwari Jadhav
Forum Moderatorrun below in Command Prompt to set HOOPS_PICTURE to opengl2 or dx11 as permanent user enviornment variable:Â
setx HOOPS_PICTURE dx11
Launch Fluent from Start. Hope it works.Â
November 20, 2023 at 5:34 pm
Rajeshwari Jadhav
Forum Moderatortry the setx command and let me know.
November 20, 2023 at 5:36 pm
rxwm79
SubscriberI have tried running the commands:
The same error as shown in the screenshot I send earlier occured again.
November 20, 2023 at 5:38 pm
Rajeshwari Jadhav
Forum ModeratorJust run setx HOOPS_PICTURE dx11 in the command prompt and launch the fluent application through the start menu.
November 21, 2023 at 10:47 am
rxwm79
SubscriberI have tried that and the same error happens again; the Fluent window opens then closes immediately.
November 21, 2023 at 5:36 pm
November 21, 2023 at 5:41 pm
rxwm79
SubscriberI have deleted that file, Fluent still does not open properly.
November 21, 2023 at 5:42 pm
rxwm79
SubscriberMy Windows is also updated to the latest version of Windows 10.
November 21, 2023 at 5:49 pm
Rajeshwari Jadhav
Forum ModeratorCan you go to .ansys folder (type %temp% in start menu) and open a file ending with the name *.FLUENT.232.out, send the screenshots of that file.
Also, search on Google regarding your ucrtbase.dll error (event logs) that you are facing while launching the fluent application.
November 21, 2023 at 9:21 pm
November 21, 2023 at 9:53 pm
November 22, 2023 at 4:38 pm
Rajeshwari Jadhav
Please have a fresh uninstall and reinstall. Also shorten PATH environment to just the C: Windows values.
Once you uninstall the application delete Ansys, SpaceClaim folder (%appdata%), .ansys (%temp%) and .cfx, .fluentconfig (C/Users/username) and then reinstall the application.
- The topic ‘ANSYS Fluent not opening from Workbench’ is closed to new replies.
6344
