January 6, 2025 at 12:46 am
nakajima.k.ay
Subscriber固体間の界面熱抵抗を求めたいです.Ansys Fluent で計算することは可能でしょうか?
よろしくお願いいたします. -
January 6, 2025 at 1:09 pm
Essence
Ansys EmployeeHello,
Is it okay to correspond in English?
If I am able to understand you correctly, I believe you are referring to Contact thermal resistance (generally due to air gap between the solids). Fluent assumes perfect thermal contact between the solids. But in case if you need to model the contact resistance, create seperate cell zone of the air of appropriate dimensions between the the two solids and then assign the corresponding thermal properties to the material.
You can also calculate the thermal contact resistance using hand calculations.
- このトピックに返信するには、ログインする必要があります。
