Ansys Fluent: How can I start drawing XY PLOT from a specific point?
    • RawadSy
      Hello!
      # Ansys #Fluent: How can I start drawing XY PLOT "Nu VS curve length" from a specific point?
      (For example, in the case of two adjacent tubes, I want to compare the number of Nusselt starting at the same point for both tubes) "See the attached pictures 1,2".
      Thanks in advance!
      You can clip the curve; use iso-clip but select the curve of interest when you do it.
    • RawadSy
      Thanks for your answer, Can you explain in detail please?
      Given the likelihood of each curve starting somewhere else I'd suggest clipping the line along the horizontal symmetry line.
      Open up Create > Surfaces > Isoclip.  Have a play, you'll need to select the curve of interest to do the clip operation.
    • RawadSy
      Unfortunately, the same problem remains (((
      Plot against x or y position not length. If needed you can manipulate the data in Excel afterwards. Which version are you using?
    • piggh18
      If anyone has been able to find a solution for this please let  me know!
Viewing 6 reply threads
  • The topic ‘Ansys Fluent: How can I start drawing XY PLOT from a specific point?’ is closed to new replies.
