February 10, 2026 at 2:03 am
February 10, 2026 at 9:34 am
Forum ModeratorUse the built in compiler and change the filename to avoid having the + in it.    mass_heat.c may work, but mass+heat.c won't.Â
February 10, 2026 at 3:36 pm
February 10, 2026 at 3:43 pm
Forum ModeratorTry in the root folder and work from there.Â
February 10, 2026 at 3:58 pm
atiqurrahman.ustb17
SubscriberYes, I did in the root folder still not working. Do I need to install the VS 2022 and if I need then Can you kindly guide me which modules I need to install?
February 10, 2026 at 4:22 pm
Forum ModeratorÂ
The whole point of the built in compiler was to avoid needing any of the VS components.Â
Check for scons on here - you can't be the first person to have seen this error.Â
February 10, 2026 at 4:34 pm
atiqurrahman.ustb17
SubscriberHow to chcek the scons and can you guide ome on that please?
February 10, 2026 at 4:37 pm
Forum ModeratorLook at the top of the page - SEARCH.Â
February 10, 2026 at 4:48 pm
atiqurrahman.ustb17
SubscriberI seached but nothing is coming.
February 10, 2026 at 5:03 pm
SamW
Ansys EmployeeHello, it looks like this is just a warning and not an error. I've seen this before and still been able to load the udf - please double-check to see whether you can load the udf after building, and/or have created the "libudf.dll" file in your 3ddp_host and 3ddp_node directories.
February 10, 2026 at 5:11 pm
atiqurrahman.ustb17
SubscriberÂ
still shows me this warning and is there any way to get rid of this problem?
February 10, 2026 at 5:13 pm
February 10, 2026 at 5:43 pm
SamW
Ansys EmployeeGlad to see that the UDF compiles and loads.
I would recommend just ignoring the warning, given that the built-in compiler seems to be working just fine. If you really want to not see the warning, you can install Visual Studio and set up the compilation environment to run with Fluent. Like Rob was saying, there are lots of threads on this forum and other places on the internet documenting that process, but it can take some time and effort to get it properly installed, hence my recommendation to go with the currently working method.
5664
1890
1414
1304
