June 19, 2023 at 7:06 am
Ashagoni Nivas
SubscriberHello
When I use fluent in workbench
Geometry and Mesh both work fine
But in the Set step, it does not work properly
The message in the Set console
       Welcome to ANSYS Fluent 2022 R2
       Copyright 1987-2022 ANSYS, Inc. All Rights Reserved.
       Unauthorized use, distribution or duplication is prohibited.
       This product is subject to U.S. laws governing export and re-export.
       For full Legal Notice, see documentation.
Build Time: May 27 2022 08:52:29 EDT Build Id: 10212Â Â
Connected License Server List:
   This is a student version of ANSYS FLUENT. Usage of this product
   license is limited to the terms and conditions specified in your ANSYS
   license form, additional terms section.
Host spawning Node 0 on machine "LAPTOP-KN02JFQD" (win64).
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 29344 RUNNING AT LAPTOP-KN02JFQD
= EXIT STATUS: -1073741515 (c0000135)
= RANK 1 PID 18396 RUNNING AT LAPTOP-KN02JFQD
= RANK 2 PID 11968 RUNNING AT LAPTOP-KN02JFQD
= RANK 3 PID 4568 RUNNING AT LAPTOP-KN02JFQD
When I turn back to the workbench
It says" Fluent Application cannot be verified to connect"
Why is this happening?
I need to finish my master's thesis urgently
Thank you..!
June 28, 2023 at 4:28 pm
George Karnos
Ansys EmployeeHello,
Check your Firewall is not blocking any communications of Fluent.
Also, Check the virus scanner is not blocking anything.Check your PATH environment variable to make sure that the PATH statement begins with c:\Windows\System32....
To check this, Open a Dos Command Prompt window and type in:
set PATHThen hit Enter.
- The topic ‘Ansys fluent error’ is closed to new replies.
