January 28, 2021 at 5:38 pm
andreyson
SubscriberHi, I'm new to Ansys and I've installed Ansys 2020 R2 Academic version.
I'm following the CornellXÂ ENGR2000X's CFD example and got stucked since Ansys Fluent Setup does not start.
I got no error messages, no warnings, nothing...
I tried to re-install, but it didn't work.
I've tried to initialize it by cmd using:
"D:Program FilesANSYS IncANSYS Studentv202fluent tbinwin64fluent.exe" ^-r20.2.0 3d -g -meshing
and I got the following
January 29, 2021 at 10:30 pmjakesmolders
SubscriberYeah Im getting the same problem. Done all the geometry and made the mesh, dragged over the fluent tab and when I go to launch the fluent it comes up with a licensing problemn
Any fixes found?nFIXED!!!!!!!nMy fix was simply changing it from six processors (Happens when you right click and edit on the fluent tab) and changing it to 4 processors. Dont know why it only allows 4 but this made it start up properly so give that a go! Hope it works!n
February 1, 2021 at 12:01 pmRob
Forum ModeratorThat means you're running the solution on 4 cpu rather than just one. Given the model size limits and that Student is for learning the tool you don't really need more. Commercial Fluent jobs without the node/cell count limit are routinely run on hundreds of cores, and KAUST used 200k or so for a project. nFebruary 1, 2021 at 2:17 pmandreyson
SubscriberMy problem is not related with the number of CPUs.nnI got no fix for the moment.nnCan anyone help me?nViewing 3 reply threads- The topic ‘Ansys fluent does not start’ is closed to new replies.
5804
