July 5, 2019 at 9:05 pm
yalgul
SubscriberHello there;
I recived this message while in setup phase.
Ansys.Fluent.Cortex.CortexCommandFailedException: An error occured in FLUENT while applying case and settings informatins.
  at Ansys.Fluent.Cortex.CortexCommunicator.SendMessage(String msg, String msgKey, String errorMessage, Boolean waitForReply)
  at Ansys.Fluent.FluentCommunicator.UpdateSetupInfo(Dictionary`2 info)
  at Ansys.Fluent.Data.SetupData.ReadCaseModelInfo(IFullContext context)
What will be the possible reason? How can I fix this error?Â
-there is no error before the setup in fluid flow(fluent) in project
July 12, 2019 at 10:10 am
Forum ModeratorIt's possible the Workbench session is corrupted, if you connect the mesh to a new Fluent task does it work?
August 9, 2021 at 7:10 am
ziyi
Subscriber.I met this problem,too.I have already connected the mesh to a new Fluent task,but it did not work.
April 20, 2022 at 11:05 am
YuJiali
Subscriber.Hello, I also encounter this problem, what is the reason, what can be solved
April 20, 2022 at 11:17 am
Forum Moderator.Did connecting a new Fluent part work?
- The topic ‘Ansys.Fluent.Cortex.CortexCommandFailedException for Windows’ is closed to new replies.
3572
1193
1076
1063
952
