ANSYS Fluent cannot find compiler for visual studio when running UDF.
    • Rosa Spence
      Have been having some issues loading a User Defined Function into ANSYS. Am getting the following warning. Visual studio is installed. Any advise how to set the compiler correctly.
      scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly
      Thank you
    • Federico
      Have you tried the Built-in Compiler within Fluent?
      • Rosa Spence
        Yes, I have also tried opening fluent through the visual studio command prompt, however that does not solve the error.
        • Federico
          Are you able to load the UDF? If you're using Fluent's built-in compiler, you can just ignore this message.
  • The topic ‘ANSYS Fluent cannot find compiler for visual studio when running UDF.’ is closed to new replies.
