October 17, 2019 at 2:51 pm
TeebaQata1
SubscriberHello,
I am following a youtube tutorial for a 3D airfoil. On ansys fluent, the tutorial says to set the boundary conditions for the intlet (Velocity inlet), where the tutorial says to set the velocity magnitude as 12m/s then press okay. the inlet dialog box of the online tutorial is in the first image below. however, the dialog box that I get has more options and different options under the turbulance option as seen in the second image. when I insert the velocity that the tutorials says (12 m/s) and press okay, I get the error message in the third image. Could you please help me out with what would be the issue or what to do?
Thanks.
October 17, 2019 at 3:04 pm
Forum ModeratorWhich turbulence model are you using?
October 24, 2019 at 3:00 pm
TeebaQata1
SubscriberI am using K-omega SS. I have manged to solve the problem. However, the error might have been in the additional equation used to solve turbulent flow (K-omega), I might have set a wrong value in the outer limit of the domain, which thus, would have caused the error.
- The topic ‘Ansys Fluent’ is closed to new replies.
5844
