Ansys Free Student Software
Ansys Fluent 19.2 crashes
    • Serwur
      Hello.
      I have a problem with Ansus fluent 19.2, when mesh is rendered on right screen and I click on that view (not only on mesh, but also on empty space) program just crashes with no reason. All other functionallity works in Tree, Task Page etc.. I would add that zooming with mouse scroll works.
      Is there any solution to fix this or my mesh is just broken?
      Thanks for answers and help.
      It's unlikely to be the mesh and is more likely to be graphics related. Can you check to see if it's a supported graphics card?  https://www.ansys.com/en-gb/solutions/solutions-by-role/it-professionals/platform-support
      I suggest updating drivers and try changing the graphics options in Fluent (Viewing -> Options) as that may help.
    • lsimurda
       Good evening,
      I am having the same problem and am hoping that you can provide more ideas on how to solve it. I checked and my graphics card is supported and my drivers are up to date. Furthermore, I tried changing the graphics options in Fluent and changing them had no effect. The problem happens when running Fluent in meshing mode in either serial or parallel mode. Whenever I have mesh shown on the right side of the screen and I hover over a zone name in either the workflow or tree tabs on the left side of the screen, the program simply closes down.
      Thank you in advance for any help.
      Which version? I've not seen or heard any other cases of this: is there an error posted anywhere?
    • lsimurda
      Good morning,
      I am using version 19.2. No errors are displayed-the program simply closes. I have been having this trouble since downloading Fluent a few weeks ago. Do you have any ideas regarding what I can try to fix this error? It is making it so that I cannot complete any work.
      There is one graphics setting, and you need to use the NVidia option to force NVidia to recognise Fluent other wise the PC can revert to the Intel settings.
    • lsimurda
      Good morning,
      By chance do you know how I access this graphics setting? Is it within Fluent?
      Thank you so much for your help!
    • tsiriaks
      Check if that display is using Nvidia or not.
      You can do this by opening CMD Prompt, then type dxdiag
      Then check on Display # tab
      Also, if it crashes like this, there might be some info in Windows Event Viewer. Launch this and look for Application Error events and see if there is ANSYS listed there.
      To set to use Nvidia card, try steps here
      https://support.serato.com/hc/en-us/articles/202305784-Changing-graphics-card-settings-to-use-your-dedicated-GPU-on-a-Windows-computer-
      Note that some Nvidia cards don't really support multiple monitors
      Thanks,
      Win
    • fulcrum
      Hi, I have the same problem here ! Fluent crashes when I try to interact with the mesh on the write side. My graphics card is GeForce GTX 1050 Ti. ANSYS is using this card.
      Is there any fix for this problem ?
      Can you check the drivers are up to date?  Does everything else work as expected (eg geometry & mesh)?
      Repeat question in /forum/forums/topic/fluent-19-crashes-without-warning-nor-error-messages/
      I'll lock this one.
Viewing 10 reply threads
  • The topic ‘Ansys Fluent 19.2 crashes’ is closed to new replies.
