October 17, 2019 at 9:38 pm
robgics
SubscriberI start up Ansys with "ansys191 -g". I click Help->Tutorials, and I get an error box:
Failed to execute default Web Browser
Input/output error.
Is there an error log somewhere I can get more information as to what the problem is? Or is there an environment variable I need to set so it can find firefox?
Thanks.
October 18, 2019 at 8:18 am
Forum ModeratorTry without the -g option.Â
October 18, 2019 at 1:41 pm
robgics
SubscriberThat just brings up a text interface. I want the graphical interface.
I did a test, and using Ansys 18.1 (ansys181 -g), I was able to bring up the tutorials in a web browser. Then doing the same thing with 19.1, I wasn't. So something has changed. Well, I'm sure LOTS of things changed between those versions, but specifically I mean in regards to opening the tutorials in a web browser.
October 18, 2019 at 5:16 pm
tsiriaks
Ansys EmployeeCan you post the screenshot of the error ?Â
What OS version is this ?
Please post the value of your PATH environment variable
October 18, 2019 at 5:49 pm
robgics
SubscriberOS: RHEL6 using Open on Demand
PATH:Â /opt/aci/sw/ansys/19.1/AnsysEM19.1/Linux64
opt/aci/sw/ansys/19.1/v191/ACP
opt/aci/sw/ansys/19.1/v191/fensapice/bin
opt/aci/sw/ansys/19.1/v191/CEI/bin
opt/aci/sw/ansys/19.1/v191/TurboGrid/bin
opt/aci/sw/ansys/19.1/v191/polyflow/bin
opt/aci/sw/ansys/19.1/v191/autodyn/bin
opt/aci/sw/ansys/19.1/v191/Icepak/bin
opt/aci/sw/ansys/19.1/v191/tgrid/bin
opt/aci/sw/ansys/19.1/v191/CFX/bin
opt/aci/sw/ansys/19.1/v191/icemcfd/linux64_amd/bin
opt/aci/sw/ansys/19.1/v191/fluent/bin
opt/aci/sw/ansys/19.1/v191/Framework/bin/Linux64
opt/aci/sw/ansys/19.1/v191/aisol
opt/aci/sw/ansys/19.1/v191/ansys/bin
usr/local/bin
usr/local/sbin
opt/rh/git19/root/usr/bin
usr/local/bin
usr/local/sbin
usr/local/bin
usr/local/sbin
usr/local/bin
usr/local/sbin
opt/TurboVNC/bin
usr/local/bin
usr/local/sbin
usr/lpp/mmfs/bin
usr/local/bin
usr/local/sbin
usr/lib64/qt-3.3/bin
bin
usr/bin
usr/local/sbin
usr/sbin
sbin
opt/puppetlabs/bin
storage/home/rug262/bin
Edit: Sorry about all the frowny faces, that's not my doing. I tried to fix it in the code view, but the web editor here will not be denied apparently.
October 18, 2019 at 9:20 pm
tsiriaks
Ansys Employeeno worries, we know it's the forum issue but yea, it's hard to read.Â
What is the output of
which firefox
also, I'm not sure if this would work for M-APDL but it works for AnsysEM products. Try setting this environment variable
ANS_BROWSER_NAME=
/firefox
October 18, 2019 at 9:34 pm
robgics
Subscriberwhich firefox:Â /usr/bin/firefox
Setting the ANS_BROWSER_NAME env var didn't make a difference.
Someone doing some sleuthing noticed that for Ansys 18.1, the tutorials were in the
/v181/commonfiles/help/en-us/help/ans-tut directory. But in our install, there are no subdirectories under /v191/commonfiles/help/en-us.
Are they just simply not installed? Is there a different procedure to install those than there was in 18.1, or perhaps they are moved to a different directory for 19.1?
Thanks.
October 19, 2019 at 1:07 am
tsiriaks
Ansys EmployeeStarting in 19.0, the 'local' help document is moved out of the main installation. So, if you need to open a local help document, you will have to do an extra installation.
But you are setting to open the online help document, so I don't think that is an issue.
What if you try
export PATH=/usr/bin:$PATH
then launch ANSYS from this terminal
October 21, 2019 at 1:53 pm
robgics
SubscriberWell, the goal is the tutorials overall. It probably wouldn't hurt to have those installed locally, but I'm guessing that they'd just open via the browser anyway, and doing that seems to be the problem.
I tried setting the PATH with /usr/bin at the front, but it gives the same error.
Thanks for the suggestions.
October 21, 2019 at 4:42 pm
tsiriaks
Ansys EmployeeYou can go to the customer portal and download the local help documents , there is '?' sign that describes how to configure to point the software to use local help document, it will NOT open via the browser.
As for your online help issue, I still think it has something to do with your PATH environment variable. Can you not load the entire module (nothing related to ANSYS v19.1 in your PATH)Â and just run the entire command to open M-APDL GUI ?
October 21, 2019 at 7:59 pm
robgics
SubscriberOk, I started a new session, and without loading the ansys module, just called ansys191 using the full path. The interface came up without complaint, but trying to open the tutorials gave the same I/O error. Exiting ansys, I then executed "firefox" on the command line without changing anything, and it came right up. So, the path to firefox shouldn't be the issue. And now I think we've removed any path issues that might be associated with the ansys module on our system.
October 21, 2019 at 8:03 pm
robgics
SubscriberOooh kaaaaay. So, something happened because now it works. I clicked the "?" icon in Ansys, the firefox opened with help. I then clicked everything under the Help menu, and everything (including tutorials) opened in a tab in firefox.
I'm now going to restart my session and see if I an recreate what causes it to not work, and then to work.
October 21, 2019 at 8:22 pm
robgics
SubscriberSo, if I start up my system, load my ansys module, start ansys and try to click anything under the Help menu, it gives me the error. I then close ansys. I launch firefox from the command line and after it comes up, without doing anything else, I close it. I then launch ansys again and this time, everything under the Help menu works. It launches firefox and displays the requested help item in the browser.
I've compared a before and after output of "env" but there is no difference. So starting firefox does not appear to be setting some env var that ansys then uses. Clearly SOMETHING is changed by starting and exiting firefox, but I do not know what it is.
October 22, 2019 at 6:48 pm
JakeC
Ansys EmployeeHi robgics,
It might be worth checking your default application settings as described here:
https://www.centos.org/forums/viewtopic.php?t=54162
$ grep 'ht' /usr/share/applications/defaults.list
text/html=firefox.desktop
application/xhtml+xml=firefox.desktop
x-scheme-handler/http=firefox.desktop
x-scheme-handler/https=firefox.desktop
where the left hand side is the MIME type and the right hand side (of the
has the .desktop application to launch.
Thank you,
Jake -
October 22, 2019 at 7:09 pm
robgics
SubscriberResult:
text/html=mozilla-firefox.desktop
I ran that grep before and after starting firefox, and nothing was changed. So running firefox isn't changing those default values. Remember also that version 18.1 works just fine on this system without having to do anything. Â
Since it's not an environment variable that gets set when firefox runs (at least, not within my ability to see), I'm wondering if it's some file permission somewhere.
 For the record, I am fully willing to believe the problem is something about how the system is configured. But since the error is on Ansys's part, and was apparently introduced by a change from 18.1 to 19.1, I'm hoping that the issue can be tracked down via help here. I'm not blaming Ansys (yet!).
October 22, 2019 at 7:11 pm
JakeC
Ansys EmployeeHi Robgics,
As mentioned earlier 18.1 had local help files installed, and the newer versions do not. Which is why it worked before.
Please add the other lines in that defaults.list file that you do not have:
Thank you,
Jake
October 22, 2019 at 7:16 pm
robgics
SubscriberThanks for that clarification on how the help changed, Jake. I see the "local help" packages in the customer portal. I may try installing those to see if that resolves the problem, that might be quicker.Â
October 22, 2019 at 7:34 pm
robgics
SubscriberI tried it with those default values, and it still throws an error.
October 22, 2019 at 7:49 pm
JakeC
Ansys EmployeeI assume it is the same error, correct?
Can you paste in the changes you made?
What happens if you run the following:
/ansys_inc/v191/Tools/mono/Linux64/bin/mono /usr/ansys_inc/v191/commonfiles/help/HelpViewer/ANSYSHelpViewer.exe
Thank you,
Jake
October 22, 2019 at 7:53 pm
October 22, 2019 at 7:57 pm
robgics
SubscriberChanges made to file:
Before:
$: cat /usr/share/applications/defaults.list | grep ht
After:Â
And yes, it was the same I/O error window as posted above.
I tried running the command you sent, and that opened Mozilla-Firefox to the "Welcome to Ansys Help" page. Â
Edit: I went in to make that change in Firefox, and it tells me that it is already my default browser.
November 7, 2019 at 7:27 pm
robgics
SubscriberAny other suggestions?
- The topic ‘Ansys fails to open web browser for tutorials’ is closed to new replies.
5664
1890
1419
1304
