Ansys Products
Ansys Products
Ansys Failed to read from IPC port : The pipe has been ended
    • David44
      Dear Everyone,nnI have some struggle while I try to open my geometrie (Space Claim) from a structural Box. nAs usual it works fine until it did not. nThe model is pretty heavy, and I don't want to lost all the joint i made in the mechanical.nDo you have any solution ? Iam currently working under the 19R2Kind Regardsn
    • tsiriaks
      Have you tried closing and reopening the project ?nDo you have the same issue for other projects ? If you don't have any other, try create a simple project to test.nIn the worst case, you might still able to retrieve some of this data from Mech database file.n
    • David44
      Thank you.nnWell i Had to start over.Regardn
    • tsiriaks
      I recommend to consult with people in this sectionnthere might be a way to scrap some parts out of your old project and put into the new onen
  • The topic ‘Ansys Failed to read from IPC port : The pipe has been ended’ is closed to new replies.
