December 6, 2024 at 10:31 am
482506
SubscriberDear ansys,ÂI try to simulate an oil tank thats partially filled in one tank and goes into another tank through a T-tube connected to another tank. First the first tank is blocked by a valve before the T-tube, vacuum is pulled on the other side of the valve (vacuum pulled in T-tube and second tank). And then the valve is opened to let the oil flow through the T-tube and into the second tank.
This is a simple schematic of the system. I used a split body and then a plane on face in the designmodeler function (I made sure of the geometry being a 2D version). But I get a error:Â
Do you know how to solve this error message or know how to prevent this problem? -
December 6, 2024 at 9:05 pm
Federico
Ansys EmployeeIt seems like your images failed to upload. Can you share again or tell us what the error message is?
