Ansys Error
    • s15.suvin
      Here, I had my 'Static structural' not solved, and when I tried
      this error showed up
      it was all well-working until I changed the material....
      I changed the material to new one I created(added) and deleted the original one(stainless steel?) on the 'mechanical' window...
      (like 'delete' delete. It asked me if I wanted to delete an object(material) and I said yes)
      I checked on the geometry setion that my bodies are re-set to material I added
      I would appreciate it if you could help me with this
    • Deepak
      In most cases, this message will occur if your model is improperly constrained or extremely large load magnitudes are applied relative to the model size. First, check that the applied boundary conditions are correct. And also check the material properties that you have added and the units.
      Thanks
      Deepak
    • ErKo
      Hi
      Also post in a screenshot the engineering data for the PLA material you defined.
      All the best
      Erik
    • s15.suvin
      Ive got problem solved... Thank you so much for replies
      It was problem with the engineering data yes... I should have re-checked it
