April 17, 2024 at 3:45 pm
SRIDHARAN PADMANABHAN
SubscriberHello,
I am an academic researcher and I design electronic PCBs using Altium and export to Ansys Maxwell 3D for simulation. Â Very recently we purchased a 32-core AMD threadripper powered-desktop computer with 128 GB of RAM and A2000 graphics card. A typical maxwell simulation of a PCB design only uses 4 cores of the 64-logical cores, which means The AMD processor seems to be just 2-3% utilized.
To speed up the simulation, and to utilize all the cores I did the following;
1) Set cores = 64 in the General options window (Tools--> Options --> General --> Desktop performance --> Maxwell 3D --> no. of processors = 64).
2) Set cores = 64 in the HPC and Analysis window (Tools --> Options --> HPC and Analysis--> Configurations --> Edit --> Machines Tab --> Cores = 64)
3) Set RAM limit = 90% in the HPC and Analysis window (Tools --> Options --> HPC and Analysis--> Edit --> Machines Tab --> RAM = 90%)
4) Enabled GPU acceleration (Tools --> Options --> HPC and Analysis--> Options tab --> Enable GPU = True)
Even after these settings, only 4 out of 64 logical processors are only utilized. This I can see from the Resource monitor window from the Task manager. Occassionally all cores are loaded for a few seconds but they eventually go back to 0%.
An eddy current simulation of a 40x40mm PCB takes around 2 hours with a coarse/rough mesh setting.
I came to know that Ansys version (R2023) of my University supports HPC license.
Please let me know if I am missing something. Is it something should I enable HPC licensing anywhere else in the license manager setting?
Your suggestions would be highly helpful in this moment.
Thank you.
Best regards,
Sridharan -
April 19, 2024 at 1:55 pm
April 19, 2024 at 2:11 pm
randyk
Forum ModeratorAdditional suggestions:
Tools--> Options --> General --> Desktop performance --> Maxwell 3D --> no. of processors is for pre/post performance - it does not affect solvers.The A2000 will not be utililized as a compute GPU for Maxwell as it only offers single precision, please uncheck "GPU"
If considering GPU compute capabilities, please see our Platform page: https://www.ansys.com/it-solutions/platform-support
However, I would tend to discourage compute GPU as very project dependant.
Consider "Auto" mode when available.Â
When selecting "Manual" mode, make sure you are enabling the correct Distribution types.
Is the project small? Perhaps the project does not require the extensive resources you are expecting. -
April 19, 2024 at 2:53 pm
SubscriberHi George,
Thanks for the suggestions and yes, it accepts 64 cores as you have shown in the images.ÂHi Randy,
Okay, I will disable the GPU in the settings.I have various designs of PCB projects to simulate and analyze. So I will try simulating them with various mesh sizes per your suggestion.
Thank you,
SridharanÂ
- The topic ‘Ansys Electronic Desktop – processor core utilization’ is closed to new replies.
5664
1890
1419
1304
