March 31, 2020 at 9:46 am
solmyr999
SubscriberHello everyone, first time posting on this forum,
I am currently learning by myself how to handle ANSYS Workbench for the sake of an internship. I want to simulate a 4 point probe measurement on a 30 microns thin tungsten plate. I have therefore created 4 circular surfaces of 10 microns radius on the surface of my plate using the face split function, made a 1A current enter through the first surface and a 1A current exit through the fourth surface.
I meshed everything and when I try to solve, I get 3 errors all saying : "solver pivot warning or errors during solving, this can come from a wrongly conditioned matrix, unrealistic material properties, an under constrained model or contact problems".
It also says that "a pivot error has been detected in the VOLT degrees of freedom of node 963".
I don't think the issue comes from material properties (I have filled in tungsten's isotropic electrical resistivity) nor contact problems because the 4 surfaces have been created directly on the plate. I don't understand why my model would be under constrained because everything is frozen.
Please help me solve this issue.
Thank you in advance.
- The topic ‘ANSYS Electric – Errors during resolution’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3862
1414
1231
1118
1015
