December 3, 2020 at 9:21 am
flodo
SubscriberHello everyone,
I have the issue that Ansys does not take decimal numbers in the Friction coefficent for frictioncal contact (see attached picture). I both tried '.' and ',' but Ansys always wants to change it to an integer.
December 3, 2020 at 1:02 pmKeyur Kanade
Ansys EmployeeWhat value you are trying? Usually it is betwen 0 to 1. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynDecember 3, 2020 at 1:04 pmpeteroznewman
SubscribernHe was trying to type 0.46 nDecember 3, 2020 at 2:53 pmGovindan Nagappan
Ansys EmployeeArray nAre you using any ACT extensions. Check and see if this popup is generated by ACT extension. From project page, go to Extensions -> View log file to see if there are any errors printednTry this and see if it helps:nCLose all Ansys and WB applicationsnOpen a directory/folder and type this address %appdata%\Ansys\ and press enternRename the folder V192 to V192_old and start WB againnWB should start with default settings. See if this resolves the issue. Any ACT extensions will have to be reinstalled after thisnDecember 3, 2020 at 5:43 pmflodo
SubscribernThank you for you comment and help. I tried do it like you described in your message but unfortunately it didn't solve the problem.nHere is a picture of the Log File:n
And the new Folder structure:n
It still shows the same error message if I want to typ in an decimal number. Do you have any other idea of how to resolve this issue?.
Viewing 4 reply threads- The topic ‘Ansys does not take decimal numbers’ is closed to new replies.
