April 16, 2019 at 8:27 am
Wolfgang Geist
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsHi,Â
one of our customers of ANSYS Discovery SpaceClaim is complaining that it is not possible to run the software when leaving the office and running demo outside - probably without Internet connection. The software is working properly on the machine the night before in house. Outside the software is crashing and producing an error message attached to this e-mail. What´s wrong?
Wolfgang Geist
April 16, 2019 at 9:05 am
Subashni Ravichandran
Forum ModeratorHello Ghost1246
Could you please confirm if your customer's .NET version is up to date? If not can you try again after updating?
If the problem still persists, can you please send us the log files from below path
C:Users
AppDataRoamingSpaceClaimLog Files -
April 16, 2019 at 9:39 am
Wolfgang Geist
SubscriberHi, I talked again with the customer. The customer is using identical hardware and is reporting following behavior:
Scenario 1: ANSYS Discovery SpaceClaim is not running. I cut the Internet connection and can start ANSYS Discovery SpaceClaim without Internet connection without problem.
Scenario 2: I use ANSYS Discovery SpaceClaim with activated Internet, I shut down the PC in the evening and restart ANSYS Discovery SpaceClaim next morning at the customer site without Internet connection ANSYS Discovery SpaceClaim is not starting and an error message is displayed – see error message already provided. Maybe you need to have a connection to the license server on the same day? This does not fit with the alleged 30-day rule. So the system behavior is not acceptable whatever reason.
April 16, 2019 at 11:23 am
Forum ModeratorGhost1246
This issue seems strange as it seems to fail only at the client location. We have had similar issues in the past but the error has been consistent. I will write to the licensing team on this. Meanwhile, could you try uninstalling and re-installing. Re-installing has worked in the past to solve this error.Â
May 2, 2019 at 6:56 am
Can you please confirm if you have tried uninstalling and re-installing?
- The topic ‘ANSYS Discovery SpaceClaim is not working/crashing without Internet connection???’ is closed to new replies.
3647
1313
1142
1075
1013
