Ansys Products
Ansys Products
ANSYS Customization Toolkit (ACT) Not Loading
    • LeoEM
      The ACT Extensions browser will not load in ANSYS HFSS 19.0.0. (Screenshot below.) I am running Windows 8.1.
      I am able to run all simulations and some of the ACT extension programs such as Savant and EMIT separately. However, the ACT extension browser will not load and does not provide any error messages to help.
      I have tried: restarting HFSS, restarting my computer, changing the temporary and project directory, resetting the temporary and project directories back to their default. On another licensed computer on the network, the ACT extension browser does load, so I do not believe it to be a licensing issue. I have launched ANSYS EDT from the command line and setting the path to include "C:Program FilesAnsysEMAnsysEM19.0Win64", and this also does not change the behavior.
      Thanks for any help!
    • tsiriaks
      Hi LeoEM,
      This is likely the issue with FIPS blocking websockets required by ACT extension. Try turning off FIPS and any security software on this machine.
      If you want to see more details of the issue, you can set QWebDeveloperExtras environment variable to 1 , then open up AEDT and right click on the blank ACT extensions page -> Inspect
      Thanks,
      Win
    • LeoEM
      Late reply, but it looks like this was the issue. Thanks!
    • tsiriaks
      Hi LeoEM,
      That's great ! Thank you for the confirmation.
      Could you mark this as ('Is Solution') , so we know there is a resolution here ?
      Thanks,
      Win
    • vvshemu
      i am getting geometry error while solving
    • vvshemu
      i have designed in catia n imported in .stp form if u observe in the tree iam getting ?mark
    • vvshemu
      if u observe in the tree there is question marl over there in the geometry section and also has like free plane parts
    • tsiriaks
      Please post this question under corresponding section. This can go to Pre and Post Processing -> Mesh Generation section
Viewing 7 reply threads
  • The topic ‘ANSYS Customization Toolkit (ACT) Not Loading’ is closed to new replies.
