Ansys Chemkin will not Export HeatperReaction when ran through cmd line.
    • djr6248
      I have previously had this issue with Chemkin, but with a different variable (BinaryDiffusionCoefficients). This time, I cannot get the HeatReleasePerReaction to appear in my CSV file when I set it to populate via
      VARIABLE heat_production_per_reaction 1 0 0 . Interestingly, it populates when I run ChemkinGUI, but I batch-process and need to run through a wrapper. A previous version of Chemkin had this issue: it would not export BinaryDiffusionCoefficients in either the GUI or via the command line. They must have fixed this bug, but a similar one appears to occur only when exporting via the command line with heat_production_per_reaction.
      Any known issues with this ANSYS?
Viewing 0 reply threads
