January 26, 2024 at 9:00 am
Ivan Lerga
SubscriberHi,
I want to do a transient 2D axisymetric simulation, but i have some issues with the CFX-Pre. I'm doing this:
- I'm creating a surface in the DesingModeler with 0 mm if thickness. Analisys type 2D.
- I'm meshing with de 2D behaviour set on axisymetric.
- When starting CFX-Pre this error appear
I can't set CFX-Pre for 2D analisys. This is the geoemtry:
Thank you,
Ivan
January 29, 2024 at 1:32 pm
V.P
Ansys EmployeeHi Ivan,
ANSYS CFX would need a one-element thick 3-D mesh for any 2-D simulation, planar or axisymmetric.
Create a mesh and export it as Fluent input file (.msh). Now in CFX pre, open the import mesh option and in it Activate the “Override Default 2D Mesh Settings”. Also set the 'Import 2d Mesh as' option to axisymmetric.
Now you are good to go. The 2-D mesh is transformed as appropriate (one-element thick 3-D) mesh in CFX-Pre. All Named Selections created in ANSYS Meshing are available as 2-D regions in CFX-Pre, including a 2-D region for the two symmetry boundaries and a region for the remaining surfaces.
January 29, 2024 at 3:42 pm
Ivan Lerga
SubscriberHi CFD_Friend,
I'll try this setup. Thank you very much.
Ivan
- The topic ‘ANSYS CFX axisymemtric 2D simulation’ is closed to new replies.
5649
1885
1403
1303
