July 26, 2024 at 9:56 am
James Wolf
SubscriberHey all! I'm a senior Mechanical Engineering student working on a fluid simulation to model flow through a stator blade. I created the physical model and imported that geometry into ansys. I'm unfamiliar with how to create the boundary around the model to indicate where the fluid is flowing. Do I have to build a barrier around my model with an inlet/outlet and import that entire mesh together? Or can I specify the fluid flow region within ansys? I'm very new at doing fluid simulations, any advice is appreciated. Thanks! street fighter 6
Viewing 0 reply threads
- The topic ‘Ansys Boundary walls for fluid flow’ is closed to new replies.
Ansys Innovation Space
1414
1241
1118
1015
