ANSYS AQWA GREMSD:.MSD INTERTIA ERROR
    • haruroslan
      Hey there!
      First time encountering this error GREMSD:.MSD INERTIA ERROR
    • Mike Pettit
      The quickest solution to this is to turn off the Calculate Shear Forces/Bending Moments option at the bottom of the Part details (assuming you are not interested in these results). However, your inertia values do look a bit unusual here... Iyy is reasonable for a 400-metre vessel (though the mass seems too small for that), while Ixx and Izz are very very large.
      Cheers, Mike
    • wang1974
      Hello, Guys. I get the same problem and i am really new on Ansys Aqwa. I can not found where can i turn off the calculation. Do your mind give me some hints to found the approach?
    • Mike Pettit
      Sure - in Aqwa Workbench, click on the part in the Outline tree at the top left, then the Calculate Shear Force/Bending Moment option is near the bottom of the Details panel at the bottom left:
      Cheers, Mike
  • The topic ‘ANSYS AQWA GREMSD:.MSD INTERTIA ERROR’ is closed to new replies.
