November 5, 2024 at 1:35 pm
November 6, 2024 at 8:23 am
Hilal Çelik
Subscribernow the older error is gone but I have met this error : CLAYES:*** SYS LOG ERR *** WTLAYD(NC) /=TOTALW. I adjust the equivalent area and mass/length according to suggestions in "Mooring issue in AQWA" but they didn't work.
November 6, 2024 at 12:41 pm
Mike Pettit
Ansys EmployeeHello,
It looks like you are using Nonlinear Catenary Cables to model your tension legs, but this cable type is not really designed for that purpose (the Aqwa solver expects a catenary shape). You could either simplify the problem by using any other (linear or nonlinear) cable type; or you could replace the cables with Tether/Riser connections, which use a finite element method to estimate the tether loads and dynamic behaviour.
I hope this helps!
Mike
