July 9, 2024 at 3:39 am
nhanani4
SubscriberHi,
I'm newbie using ansys aqwa.
In my study, multi - floating structure connect use ball and socket connector.
I want to ask:
1) Did the detail of ball connector should key in such as stiffness about local X and other if I want to used the ball connector? Or I use the ball connector but the detail of connector should i blank and run the simulation like picture two?
2) What the default stiffness of ball connector if the detail of blank connector is blank?
3) The ball connector i put has the angle like picture 1. Should i key in the detail data like picture 2. But what formula should be calculate for the detail connector?
Thank you for helping me.
July 10, 2024 at 3:59 pm
Shuangxing Du
Ansys EmployeeThe items in the Joint Properties are optional. If there is no data being typed in, the default is zero. For a ball and socket joint, its joint local axes coincide with the axis directions of the global coordinate system axes at the initial definition localtion.
July 11, 2024 at 4:27 pm
nhanani4
Subscriber1) what is the formula of stiffness about global x, stiffness about global y and global z should I key in?
2) I want to connect my multi-floating structure in that picture arrangement but only the ball and socket connector can run the data horizontal force. What should I do to run simulation with change the ball socket to hinge?
Thank.
July 12, 2024 at 8:51 am
July 16, 2024 at 6:06 pm
nhanani4
SubscriberMean I should make some calculations for key in the data for stiffness about X,stiffness about Y, and stiffness about z?
I think that ball socket has default data because when I blank that section,I still get the data joint ball socket.I have wrong idea right?
July 17, 2024 at 4:21 pm
Shuangxing Du
Ansys EmployeeCould you please show the contents of the data category 12 of your input data file with the extension name of .dat generated by Aqwa in Workbench? I do not think there is any default non-zero values for the ball and socket joint stiffness.
October 3, 2024 at 1:02 am
nhanani4
Subscriberwhere i canfound data category 12 in .dat file? i see until deck 17. can you help me?
October 3, 2024 at 1:58 am
- The topic ‘ansys aqwa : ball connector and socket’ is closed to new replies.
5674
1890
1419
1304
