October 3, 2024 at 3:26 am
nhanani4
Subscriberhi..
i want to get the 6dof motion data for surge,heave,roll, pitch , sway.
how can i get the result?which one it correct and what the difference between them?
i) structure nposition > actual response> global x for surge ?
ii) structure position ? RAO based reponse > global x for surge?
i get the i) heave -4.9 m it is okay to get negative?
i get the ii)Â heave 0.0034 m ?
which want the correct data for surge motion?
tq
October 3, 2024 at 11:24 am
Shuangxing Du
Ansys EmployeeIn 13.5.3. Motions at Drift and Wave Frequency (ansys.com), there are some descriptions of RAO based responses. If you want to get the 6 DOF motions, please use Structure poistion - actual response.
The actual responses give you the actual LOCATION and/or OREINTATION of a structure's COG. If the actual response -> global z result at a time step is -4.9m, it just means that at that time, the COG in the global coordinate system (the origin is at the mean water level) is at -4.9m in the vertical direction. Â
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
4597
1495
1386
1209
