January 25, 2023 at 3:39 pm
Tom Ber
SubscriberHiÂ
Do any of you know where to find documentation on "InternalObject"?
The only information i found is that internalobject is for advanced use
 it would be very helpful.
Regards
January 27, 2023 at 1:09 pm
Aniket
Forum ModeratorInternalObjects, as the name implies, are for internal use purposes. These are neither documented nor tested. So it is not recommended to use them in your code as the API may change without any notifications over versions.
Still, if you want to use it, you can use dir(mesh.InternalObject) and/or help(mesh.InternalObject) to get some pointers.
-Aniket
February 10, 2023 at 8:00 am
Tom Ber
SubscriberGreat! Thanks a lot!
- The topic ‘Ansys API’ is closed to new replies.
Ansys Innovation Space
1007
935
858
792
