Ansys Apdl
    • sadaqathussayn
      Hi everyone!
      I am working on a bridge model in Ansys Apdl. When i tried to apply stresses (Von Misses), it showed this error "The request data S is not available. The PLNSOL command is ignored" And when i tried to import this Ansys  file into UM (Universal Mechanism) software to create a bridge.rst file, it showed this error: "Inadmissible DOF constraint UX found in node 1203. Remove all DOF constraints and repeat the calculation" In this regard, suggestions are required. I've included the screenshots. Thank you very much.
    • ashish.khemka
      When you say that you tried to apply stresses - do you intend to apply initial or residual stress? The image indicates that you are evaluating the results for von-Mises Stress and the stress data is not there. Can you try reading the results for a load step and they try evaluating the results? Also, if this does not work then try issuing OUTRES, ALL,ALL and then resolve the analysis.
      Ashish Khemka
    • sadaqathussayn
      Thank you, Ashish Khemka, for your reply. I have successfully solved the above problem. I just added this code:
      ESLN, s, 0,all
      CM,ESTRS,ELEM ESEL,all ALLSEL,ALL
      Then I select entities and desired nodes on the bridge. Nodes were also selected by NSEL and KSEL commands, but I selected them manually. To import into UM software, I used the UM,10,1,1,1 command.
  • The topic ‘Ansys Apdl’ is closed to new replies.
