March 29, 2018 at 4:46 pm
marikaza6
SubscriberHello, I want to ask if it is possible to export my solution's geometry from ansys aim to workbench or a cad program. My project is polymer extrusion through a nozzle and I need to know the diameter of the material that is coming out from nozzle.
March 29, 2018 at 10:32 pm
peteroznewman
SubscriberI documented an approach to export Static Structural deformed shapes into a CAD system in this discussion.
Please reply if this works for your polymer extrusion. If you want to share your model, I can try to export the shape also.
March 30, 2018 at 9:57 am
March 30, 2018 at 11:20 am
peteroznewman
SubscriberNice photo. You marked your post as "Is Solution" and this topic is shown as Solved. Does that mean you were successful exporting your deformed geometry to Mechanical or a CAD system?
March 30, 2018 at 11:54 am
March 30, 2018 at 6:42 pm
peteroznewman
SubscriberPlease use File, Archive and create a .wbpz file then use the Attach button to upload it to a post, then I can open it in my copy of AIM 19.0 and give it a try.
April 2, 2018 at 12:52 pm
marikaza6
Subscriberhttps://www.dropbox.com/s/y9x33xm54y8d5e1/test.wbpz?dl=0Â
This is the link to my wbpz file.Â
April 3, 2018 at 2:56 pm
peteroznewman
SubscriberHi Marika,
I downloaded the archive. You should also be able to attach it to your post. Unfortuantely, when I restore the archive in AIM 19.0 I get an error message.
This is probably an ANSYS AIM bug that will be fixed in 19.1
Do you have a program to create file archives like Winzip or 7-zip? If so, please zip the entire folder containing the project and put that in your dropbox. That should open for me without an issue.
April 3, 2018 at 8:08 pm
marikaza6
SubscriberMy file is .rar here is the link.Thanks for your help. https://www.dropbox.com/s/fbqzp8z4e06t8p0/test.rar?dl=0
April 4, 2018 at 2:21 am
peteroznewman
SubscriberHI Marika, I unzipped your rar file, but I got errors trying to open test.wbpj with AIM 19.0.
Does your AIM open this file?
Did you create the rar file after you exited AIM?
I will just have to create my own model. What do I need to do?
- The topic ‘Ansys aim and workbench’ is closed to new replies.
4818
1587
1386
1242
