May 25, 2024 at 8:38 pm
n n
Subscriberhello, are the material used in ansys additive database homogeneous and isotropic? for exemple the TI6AL4V?
May 28, 2024 at 10:38 am
Akshay Maniyar
Ansys EmployeeHello,
If you check the material property values for Ti6Al4V, you will find that it has orthotropic thermal conductivity. You can check the material property values under Engineer database for othe rmaterials.
Thanks,
Akshay Maniyar
- The topic ‘ansys additive material database’ is closed to new replies.
