August 6, 2023 at 12:29 pm
n n
Subscriberhello, i was wonder to ask what are the origins (Manufacturer and specific apparatus model, Country) of all used equipment ( machine)Â and reagents in ansys additive, single bead simulation.
thnx
August 7, 2023 at 2:33 pm
John Doyle
Ansys EmployeeIt is an interesting question, but kind of outside the scope of this forum. You should conduct a study on Additive Manufacturing History. There are many textbooks on the subject. In general, I believe the first patent described it as Rapid Prototyping using plastics(late ~1970s). Metal Additive was not introduced until early ~1990s. I believe it was originally researched at Wake Forest and MIT, but there were probably other institutions and corporations researching this in parallel as well.
August 7, 2023 at 2:43 pm
n n
Subscriberthnx for your response, can u tell me please what is the Protective Atmosphere used in ansys additive, argon gaz ?
August 7, 2023 at 3:41 pm
John Doyle
Ansys EmployeeIt depends on the machine, but argon, nitrogen, a vacuum, or some combination have been mentioned in the literature.
- The topic ‘Ansys additive machine and equipment in single bead simulation’ is closed to new replies.
5719
