ANSYS Additive – Build files import ERROR
    • Dave123
      I use ANSYS Additive to export build processor files for simulations.
      When I import EOS machine build files, I get this error:
      Input file(s) was not loaded sucessfully. OpenJZ: EOS_ERR_NO_ERROR, Congifuration: EOS_ERR_FILESYSTEM_IO_ERROR
      Any idea what would be the cause?
      Thanks.
    • John Doyle
      One possible explanation might be (...from the Known Issues and Limitations Section of Additive User's Guide (R2022-R2 beta)): "When attempting to import an older EOS build file, the Additive application may reject it since version 2.8 of the EOS API is stricter in regards to the OpenJob format. If this happens, you will see an error under the import availability status like this: Input file(s) was not loaded successfully. OpenJz: EOS_ERR_OPENJOB_INVALID."
    • Dave123
      John For build files import, can the Additive applicationread multiple parts ' slices, or it can read only one part?
      Thanks.
  • The topic ‘ANSYS Additive – Build files import ERROR’ is closed to new replies.
