ANSYS ACT script for getting node ID of maximum results.
    • pragvansh.sharma
      I am having multiple result objects which are scoped to different named selections can anyone share how we can create a ACT script for getting the node ID for the node having the maximum value of result for each result object seperately. I want to get a list for these node ID's.
    • erik.kostson
      Hi
      You can find similar scripts in the discuss asnsys forum which you can change and tailor as needed to do what you need.
      https://discuss.ansys.com/discussion/1761/insert-normal-stress-get-maximum-and-find-which-nodes-have-the-max-stress-value
      https://discuss.ansys.com/discussion/3542/write-max-vm-stress-for-each-part-in-named-selection-to-file#latest
      All the best
      Erik
  • The topic ‘ANSYS ACT script for getting node ID of maximum results.’ is closed to new replies.
