3D Design
3D Design
Ansys “ACPCompositeDefinition.h5” Issue
    • benjaminmoy
      I am trying to run an Ansys simulation with composites on an ACP pre. When I open the project it says files are missing, specifically "ACPCompositeDefinition.h5". I can't figure out how to fix this issue.
    • Ashish Khemka
      I checked with the team and this issue is quite uncommon. What may be happening is:
      • Another process is blocking the file so that ACP cannot regenerate it. For instance Mechanical or if a composite failure tool update is running or hanging
      • Special characters or spaces in path and project name: If you are using a recent version of Ansys WB, then it is quite unlikely that this is the critical issue.
      • There is an error in ACP. I would open ACP and check if you can update the model. If the update finished successfully, then call an update from WB (you can keep ACP open).
      Please see if this helps.
      Ashish Khemka
