Ansys Products
Ansys Products
Ansys ACP – creating accurate material
    • mateusz.urbaniak
      Bbp_participant
      im a formula student engineer and I've started working on composite simulations.
      Im trying to simulate sandwich structures and I want to achieve best results by defining the materials we use, since in engineering data source there is a limited choice. I also want to validate the results with existing structures.
      I've just learned about ansys granta edupack and I am on my way to getting a licence for that. Is it any good for my application?
      We use Angeloni gg200t for example and some Toray based fabrics. We use resin infusion process using epoxy resin. I have datasheets for every material.
      How and what information do I have to input to Ansys to achieve best results and acurately simulate our existing laminates?
    • Raman Babu
      Hello Mateusz,
      ACP requires lamina-level properties for structure behavior evaluation. You need to define orthotopic elasticity properties for strength, and orthotopic stress/strain failure limit for first-ply failure simulation.
      If you have a material that is not available in Engineering Data, you can directly feed the above data in orthotropic elasticity & orthotropic stress & strain limit. If you have fiber and matrix properties separately, you need to evaluate combined properties through experiments or using material design tool.
      Raman Babu
