October 6, 2024 at 9:28 am
Masataka Nakamura
Ansys EmployeeYou can monitor your Ansys Access costs more closely by using the Azure tagging feature. The Ansys Access tagging feature is linked to the Azure tagging feature, allowing you to add specific Azure tags to resources created with the Ansys Access.
e.g.
User-defined tags to be assigned to each resource can be specified from the tenant administrator page.
e.g.
Please see following links for details of Ansys Access tagging feature.
-Â Â Â Â Â Â Â Â Links
You can view the costs of tagged resources by adding a tag filter in Azure cost analysis.
You can also assign tags to each resource and use the tags to manage different aspects of your Azure resources. For more information, see the following Microsoft link:
Ø Microsoft Learn - Use tags to organize your Azure resources and management hierarchy
- The topic ‘Ansys Access Billing / Tagging’ is closed to new replies.
6600
1311
