Ansys Products
Ansys Products
ANSYS Academic Teaching Introductory vs. Academic Research Mechanical and CFD
    • lheinrich6
      My college has the Research Mechanical and CFD version where I can see the von Mises and other deformation results of a simple beam. However, on my personal machine with the teaching and introductory version, I cannot see those results.n
    • tsiriaks
      Is there any error message ?nOn your personal machine, go to %temp%\.ansys folder, sort by date modified to see the recent ones, and open them up and scroll to the bottom to see if there is any DENIED entry. If so, post it here.nNot sure if yours is similar to this but you can try check it out, especially those first few commentsn/forum/discussion/comment/61056#Comment_61056n
    • lheinrich6
      I have been denied.nn
    • tsiriaks
      That part is actually fine.nIf this is the only part with DENIED entries, I don't think this issue is related to licenses. It might be some issue in the software setting.nCan you post the screenshots to show the one that you can see results and the one that you can't see ?n
    • lheinrich6
      The School's Version that works the way I need.nThe Educational version I personally downloadednn
    • tsiriaks
      Hmm, it shouldn't hide these options even if you didn't have licenses. Something else is wrong about this. nTry closing all ANSYS applications on your machine, then open up CMD Prompt and enter the following commandnmove %appdata%\ansys %appdata%\ansys.oldnDoes this help ?nIf not, see if you have an install.err file under (default location) C:\Program Files\ANSYS Inc\ANSYS Student , and post its content if existn
Viewing 5 reply threads
  • The topic ‘ANSYS Academic Teaching Introductory vs. Academic Research Mechanical and CFD’ is closed to new replies.
