February 15, 2023 at 8:33 pm
Tarun Kumar
SubscriberI have a situation where I have to export a .aedt file containing a encrypted 3D component (.a3dcomp) file to CST studio.Â
Normally to export .aedt files to CST studio, .aedt and .sm3 file are required, but in this case if I follow the usual steps will the component encryption get passed to CST? My goal is to preserve the component's encrytion when importing it to CST.
Can someone help with this.
Thanks
Tarun
March 2, 2023 at 5:20 pm
Praneeth
Ansys EmployeeHi Tarun,
Thank you for reaching out and your patience is much appreciated.
Please share more details on your query to help us serve you better.
I am wondering on how it is possible to export the AEDT files directly to CST studio?
Best regards,
Praneeth.
- The topic ‘Ansys 3D model Encryption’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1220
1118
1015
