February 11, 2025 at 12:22 am
mtk621
SubscriberI have downloaded and installed the 2025 R1 Student version of Ansys. However, even though motion is included in the student version I cannot use it. It doesn't appear in the workbench, it doesn't appear as an option in Mechanical, and it's also weird when you select "View All / Customize" motion is an option but it doesn't appear in the toolbox regardless of whether it's checked or not. If I launch Motion Pre directly I get the following error code: "No Such Feature Exists, Feature: vmotions_pre ... Flexnet Licensing Error -5357" I have tried clearing the temp folder, deleting the app data folder, deleting the start menu folder, uninstalling the product, deleting the program files folder, and the reinstalling and it hasn't worked. The licensing server isn't running I have flexnet and web licensing turned off in the licensing settings. I have also tried renaming the %temp% and %appdata% ansys folders to have the .old file extension. As well as checking for the .lic file in the /Shared Files/licensing folder but there isn't anything there.Â
The most recent full error code I received when trying to launch Motion Pre was the following:Â
2025/02/10 18:10:38 Â Â INFO Â Â Â Â Â Â Â Â ANSYSLI_CMD=C:\Program Files\ANSYS Inc\ANSYS Student\v251\licensingclient\winx64\ansyscl.exe -acl 43108.20268 -nodaemon -log C:\Users\Brendan\AppData\Local\Temp\.ansys\ansyscl.DESKTOP-EC3GOHH***********
2025/02/10 18:10:38 Â Â INFO Â Â Â Â Â Â Â Â ANSYSLI_INITIALIZATION_FILE=No initialization file found.
2025/02/10 18:10:38 Â Â INFO Â Â Â Â Â Â Â Â ANSYSLI_PRODORD_FILE='C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\prodord\ansysli.prodord.xml'
2025/02/10 18:10:38 Â Â INFO Â Â Â Â Â Â Â Â ANSYSLI_TIMEOUT_FLEXLM=15
2025/02/10 18:10:38 Â Â INFO Â Â Â Â Â Â Â Â Configuring ACL Core
2025/02/10 18:10:38 Â Â INFO Â Â Â Â Â Â Â Â ACL Core Initialized
2025/02/10 18:10:38 Â Â INFO Â Â Â Â Â Â Â Â ANSYSCL_PORT=57657Â
2025/02/10 18:10:38 Â Â INFO Â Â Â Â Â Â Â Â Listen Socket Created
2025/02/10 18:10:38 Â Â INFO Â Â Â Â Â Â Â Â ANSYSLI_CLIENT_IDLE_TIMEOUT=0
2025/02/10 18:10:38 Â Â INFO Â Â Â Â Â Â Â Â ANSYSLI_IP_OVERRIDE option is off.
2025/02/10 18:10:38 Â Â INFO Â Â Â Â Â Â Â Â Ready to accept connections.
2025/02/10 18:10:39 Â Â CLIENT_ACCEPT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â
2025/02/10 18:10:39 Â Â CLIENT_CONNECT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 43108:43108:FEAT_VMOTION:Brendan@DESKTOP-EC3GOHH:winx64 Â Â Â Â Â Â Â Â Â Â
2025/02/10 18:10:39 Â Â INFO Â Â Â Â Â Â Â Â ANSYS_LICENSING_SERVICE_PRIORITY=fnp,web-elastic
2025/02/10 18:10:39   DENIED        vmotion_pre           25.1 (2024.1030)       1/0/0/0  43108:43108:FEAT_VMOTION:Brendan@DESKTOP-EC3GOHH:winx64          Â
    No such feature exists.
    Feature:    vmotion_pre
    License path:  C:\Users\Brendan\AppData\Local\Temp\\cfd72cb7-bb1a-4e0d-abcd-ef2668c81290;
    FlexNet Licensing error:-5,357Any help would be appreciated. Also the license file it points to in the temp folder doesn't seem to exist.Â
February 12, 2025 at 4:15 pm
mikolaj.bogajczyk
SubscriberI also have problem with Ansys 2025 R1 Student version. No Ansys Motion in Workbench, cannot run standalone version too.
Was Ansys Motion removed from Student version?
February 19, 2025 at 10:04 am
Rajeshwari Jadhav
Forum ModeratorHi,
We are checking this internally.
February 20, 2025 at 10:41 am
Rajeshwari Jadhav
Forum ModeratorHi,
This will be fixed in 25R2. Interested users please migrate to 24R2 student product.Â
May 19, 2025 at 4:45 am
karmawangchen111
SubscriberWhy I am not able to select geometry faces for checking or solving directional deformation
- The topic ‘Ansys 2025 R1 Student Licensing Issue’ is closed to new replies.
5639
1885
1403
1303
